I am making an entirely custom plane and used grasshopper to create the fuselage, wings, and engine pylon to make it very parametric. When moving on to blending the fuselage into the wings I am running into a ton of problems. I have tried a bunch of ways to blend this, ideally in grasshopper, but have not had any success. The main culprit is the trailing edge which creates some unwanted geometry. Should i be doing this blending entirely in rhino by making surfaces myself? I attached the un edited grasshopper version, aswell as pictures of my problem area. It is a surface but I’ve also tried with it as a full solid.
Airframe.3dm (887.5 KB)
I also tried not including the radius in the fillet and then revolving but it also doesn’t do what i want.
