Difficulties with editing parameter names in GH2
I’m trying out GH2 on MacOS and finding that my ability to use and edit parameter names is crippled compared to GH1.
  1. In GH1 the ability to have an output parameter name copy over to an input when wiring to that input is toggled on and off with the alt/option key. When activated, the wire being dragged turns red to indicate the parameter name copy function is active. It would be fantastic to have this behaviour on GH2 as well :folded_hands:
  2. After right-clicking on a parameter, in GH1 the tab key makes the parameter name field active for editing, in GH2 tab key does nothing. Please add this.
  3. The parameter name field in GH2 lacks very basic editing functions: double-clicking does not select a word, triple clicking does not select-all, unable to cut, copy, or paste!
My workflow in GH1 is based on creating meaningful parameter names. This helps tremendously when returning to sections of a definition later on, sometimes years later, and quickly understanding what data is flowing where. Bug hunting is greatly aided by this practice. I would dearly love to be able to work this way in GH2 as well.
Hi Leo,
Added a feature request for each of these. Thanks for reporting.
RH-97601 Alt/option name propagation when wiring
RH-97602 Tab should activate the parameter name field
RH-97603 Parameter name field lacks basic text editing
Much appreciated Japhy!
Really like the well written and insightful requests. I also really appreciate your mentioning of the need for find/replace across nicknames. That would be so immensely valuable for any users who work with meaningful parameter names!
Another bug with the current implementation of custom parameter names: They disappear when the menu item View > Show Full Names is selected.
Compare
With
Strangely the Listen components are unaffected, but the other components I’ve tried so far lose their custom names display when Show Full Names is on.
Bumping this in the hopes of getting a ticket added for “Custom parameter names disappearing when Show Full Names selected”
So when you have a long name 'Specifications Strings …" what are you expecting when Show Full Names is off? The first n digits?
I would expect any custom name to stay unchanged when Show Full Names is off.
This is consistent with Show Full Names behaviour in GH1.
I think that abbreviation of a custom name would obfuscate its meaning.
I found a existing youtrack (dev) concerning this and added this thread.
Name transfer works now with alt or option.
nametransfer
Beautiful! The little name tag that moves with the wire is better than how it works in GH1.
Thank you!!!
