Difficult selecting frontmost surfaces
Okay, I must be missing something essential, but I often find myself frustrated when I can’t select the front most surfaces if there are other surfaces behind.
If I’m in no command then selection works as expected (nearest surface is - of course - selected when clicking on it), but when in a command then it’s near hopelessly difficult to select the nearest/frontmost surface.
I’m sure this behavior can be disabled, no? What am I missing?
Fig 1. First selecting while in no command, then running MergeSrf and trying to select the chamfer surfaces :
// Rolf
Try the PickRejectionFuzz command. Change the value to see if the results change. I use a value of 5. If this works, add it to your startup.
I’ve had this here for a long time, but if my memory is correct, the purpose of that command is to reduce selection ambiguity.
Dan
Yess! That did the trick. Many thanks!
// Rolf
What magic is this? Can someone elaborate on what this undocumented command does?
-Willem
Yeah, we’re feeling rather fuzzy and rejected here… :stuck_out_tongue_winking_eye:
Judging from the name, and fuzzy memory, I think that is probably @mikko 's command…
Please don’t burn me at the stake for this sorcery! :grinning:
I believe the command fine tunes the selection process by reducing the radius at the cursor so that fewer objects are considered as selectable because fewer fall within that radius.
Or I don’t have the fuzziest idea.
Your pick. :slight_smile:
Dan
