German language UI
@Joachim_Kuntz ?
We have the Zurücksetzen (_Revert) command in the file menu.
The following dialog has Zurückkehren in it’s text.
In the file toolbar the tooltip shows a next wording: Wiederherstellen.
That’s 3 different words for the same thing.
Confusing.
I looked in the help for the Zurücksetzen command.
This leads me to _Reset.
When I search for Zurückkehren, then the help shows what’s expected.
I wish the naming was consistent.
Imagine an uninitiated user.
@Charles what a mess indeed. Tomorrow, while updating RH9 strings, I’m going to look into this.
@Charles As for Zurücksetzen / Zurückkehren / Wiederherstellen: I presume the latter to be the correct one (eine Datei wiederherstellen). Therefore, the corresponding Help topic should also be named Wiederherstellen, instead of Zurückkehren. Then again, Wiederherstellen is already in use for Restore. Not to mention Revert, which is localized as Rückgängig in the menu and as Zurückkehren in the command line. Zurücksetzen (Reset), on the other hand, has nothing to do with it, since it refers to Rhino’s system reset (Fabrikwerte).
It will take me a while to sort it all out. Maybe @Daniel_Wunsch might assist me in this plight, next week, when we’re back in the office.
Perhaps using more words would help, like here in UltraEdit from 2002:
Restore Saved Version?
Puh.
