I import an image vis Picture, then split the image to use for different models and some notes. When I change the transparency on one image, they all change to the same opacity…
I guess it is the same material for all pieces after it is split.
Is there a way in Rhino to change each piece can have different transparency values? Or should I split the image up before and insert via Picture each one separately?
