Different result from print
I extended @Pascal s script by a single line that prints the current DisplayMode:
print ('Aktiver Anzeigemodus:',sc.doc.Views.ActiveView.ActiveViewport.DisplayMode.LocalName)
Simple thing.
When I run the script from the ScriptEditor, the result in the command area is:
Aktiver Anzeigemodus: Arctic
When I run the same script from a button or shortcut by _-RunPythonScript “T:\Desktop\CycleDisplayModes.py”, this is the result:
(‘Aktiver Anzeigemodus:’, ‘Arctic’)
Hmm?
Are there different Python engines in use?
I need clarification.
CycleDisplayModes.py (1.8 KB)
Without checking I might imagine that running from the ScriptEditor it is running in Py3 whereas from _-RunPythonScript it might be running in Py2…
Why the difference in printing, will have to test…
It’s because Python 2 reads the brackets as a tuple after the print statement, where as in Python 3 that’s a normal function call.
[edit] bracketed expression(s) separated by a comma outside of a function call are a tuple.
Ah ok.
That’s not the problem as long as we know which Python gets used.
In the meantime I verified which version is used when:
_-RunPythonScript → 2.7.12 (2.7.12.1000) [.NETCoreApp,Version=v3.1 on .NET 7.0.17 (64-bit)]
_-ScriptEditor → 3.9.10 (tags/v3.9.10:f2f3f53, Jan 17 2022, 15:14:21) [MSC v.1929 64 bit (AMD64)]
_EditPythonScript → 2.7.12 (2.7.12.1000) [.NETCoreApp,Version=v3.1 on .NET 7.0.17 (64-bit)]
Means _-RunPythonScript doesn’t execute 3.9 scripts.
Py3:
print("A")
>>>A
print("A","B")
>>> A B
Py2:
print("A")
>>>A
print("A","B")
>>> ('A',  `B`)
I see that. So in order to have a py2 and py3 compatible print statement with multiple items in one line…? This seems rather laborious:
print("{} {}".format("A","B"))
It does, I have at least one script here that uses libraries only available in Py3 and it works fine from an alias using _-RunPythonScript. You need to have #! python 3 at the top of the script.
I tried:
#! python 3
and
#!/usr/bin/env python 3
No effect when using _-RunPythonScript.
Nonsense.
I missed to type the !.
That was me at first, sorry, I edited that later.
While the current confusion is cleared, this issue shouldn’t exist.
When I use the ScriptEditor I expect the script runs exactly the same when calling it by RunPythonScript.
Otherwise it is a bug or glitch.
I don’t know who the Python master is, so please @pascal .
The thing is ScriptEditor can run either Py2 or Py3 depending on which template/model you use. The active version is shown in the lower right hand corner.
RunPythonScript needs to be told which version to use. I think it defaults to Py2 if nothing is specified at the top of the script. Edit: confirmed.
Inside a script, how does one determine which version of Py is running the script? I have a couple of scripts which I can maybe add a switch to do things differently depending on which is running.
I never thought to try it before, but the new IronPython 2 components support __future__, so it’s also possible to:
#! python2
from __future__ import print_function
print('a', 'b', 'c', sep = '_^_', end="\n\n And we're done!!\n\n")
import sys
print(sys.version)
