Differencing surface model with a mesh model
Aloha all,
I am trying to use a mesh model to Boolean difference a surface model. Is this possible? I keep getting difference failed message. Any input is greatly appreciated.
Sam
You can under two (rather tough) conditions:
  1. You need to transform your surface model into a mesh first.
  2. Rhino’s mesh intersector needs to be able to handle the situation.
The Rhino command MeshBooleanDifference will automatically transform your input objects to a mesh, so #1 is no problem. The main problem is #2 - Rhino’s mesh intersector is very weak, so mesh Booleans don’t succeed all that often…
In any case, the resulting object will be a mesh. You cannot subtract a mesh from a surface and have a surface result.
If your mesh to subtract is VERY light, you could try MeshToNurb on the mesh, and then use a normal BooleanDifference. Read the Wiki page on MeshToNurb to see what the limitations are.
HTH, --Mitch
Tried the mesh to nurbbs but my computer crashed! Maybe I gotta convert the file
To a surface in some other program.
