Difference in surface quality after using move face, trimming etc
Hopefully a simple solution to this one.
When trimming and using move face to manipulate profiles, there are differences in the surface quality which are visible in pen view (which I use as a quick presentation to clients). Is there a way to clean up these solids so that they all look the same? Or a better way to build and manipulate these parts in the first place?
under stairs.3dm (2.9 MB)
Many thanks,
John.
Your file has quite a few bad objects (parts of the profile)
a quick way for these profiles is to use one section and a rail and then Sweep1. The only draw-back is that you end up with a seam in the middle. Other than that the geometry stays clean.
Hi Gijs - I often run into this seam issue. Are there any cool tricks to eliminate it? Also, maybe down the line, we could get a seamless option in the Sweep tool itself?
How about putting the profile in one of the corners and shear (45 degrees)?
Thanks Gijs,
Yes, I have used this method before and it works well, but for cutlist purposes its handy for me to have 4 separate parts. I will sometimes do the sweep and then cut with cutting planes, but it takes longer than I’d like.
John
This still generates a seam unfortunately.
