Hello everyone,
I have created a Grasshopper script that, among other things, generates diagonals based on given coordinates. When I run this script directly in Grasshopper (outside Revit 2024), everything works fine.
However, when I open the same script in the Rhino.Inside.Revit environment, it no longer recognizes those diagonals.
@MSAwan Great if it looks like that for you when you open it through Revit. For me, it still doesn’t look that way, which means it’s either something related to Revit or I need to install the latest version of Rhino.Inside.Revit. It looks like that for me too when I open it directly. Which version of Revit are you using? Thanks again!
