Diagonal interpolation
Hello again ! Do you know how can I do a diagonal interpolation between these points? I tried with many data tree combination, but in this moment this problem is above of me. Thank you in advance!
01_pattern_Radu_refacut_help_2.gh (34.1 KB)
Check this maybe it is a long way, use the lines to sort your result or use the sorted surfaces to create you new points
01_pattern_Radu_refacut_help_res.gh (38.8 KB)
Thank you so much for your help!
@anon39580149, can you explain me a little bit the reasoning behind it, please?
The idea is to align and sort points based on the original grid than group them, you need study it to understand , and maybe you find better solution.
this is a simple example
I understand. Thank you!
