Hello, how are you?
I’m having an issue with contour… I need a 30-degree contour to start from every point as a 90 degree…But it keeps using only one point as a reference… does anyone know how to coincide all the points??
You didn’t internalize your geometry.
Wow, Thank you so much! Helped a lot!
Thank you so much! I didn’t know this command! Helped a lot!
Here’s a different method. Instead of a vector to determine angle you can dial plus or minus 90 degrees:
LGTI_2020Apr23b.gh (16.3 KB)
