-DevLoft should remember Density setting
-DevLoft should remember the previous setting of Density rather than reverting to the default of 4 each time the command is started. I unrolled a set of planks and a increasing Density from the default yielded better results, but I had to increase the density each time I used -DevLoft.
Hi David - got that, thanks.
https://mcneel.myjetbrains.com/youtrack/issue/RH-48314
