Devide by verts not working
Hi. I’m a new Clayoo user and wanna Divide a flat face by 2 separate points but only close neighbor points can be selected as the second point (look at the attached pic). How can I select other far points as the second point in Divide command? Am I doing something wrong (most likely)?:thinking:
Clayoo%20Divide
Hi @Meysam_Ebrahimi,
It is working fine on the latest version of Rhino 6. Try to change the order of vertex selection (sometimes helps).
12-11-2018%209-02-55%20AM
If still not working, we have different ways to get the same result:
  1. Use the _ClayAppendFace tool with “Autoquad=No”. This will allow you to create a face as big as you want to cap half of the heart shape.
  2. Another way is to use the ClayAppendFace to create one vertical face. _ClayFill to create the face to fill the rest of the hole. And delete the edge that you don’t want.
Let us know if you have any problem.
Cheers,
Hi @Xavi_Marrodan. Yes. It will help. Thanks for help :pray:
