I have a large data set where I am trying to determine whether the points form lines within a specified tolerance (1/16").
Here I have a set of lines.
I drew a line between the end points, offset each side by 1/16" and closed offsets to create a boundary box. Using SelBoundary shows that all the points are inside the box and are within the tolerance. Thus they form a line within 1/16".
Is there any way to do this rapidly?
If I create a spline through the points, then CONVERT with a tolerance of 1/16" I get two lines. So that’s not working out here.
Hello - I don’t know if this is what you need but just in case - it asks for a max deviation and points - if it can calculate a line from those points from which no point is farther than max deviation, it will create the line…
To use the Python script use RunPythonScript, or a macro:
_-RunPythonScript "Full path to py file inside double-quotes"
