Because I need to maintain a legacy Rhino.NET plugin on both Rhino 4 and 5, I need to determine whether it is running inside version 4 or 5.
All I can find is in the IRhinoApp interface:
GetApplicationName
GetBuildDate
Does anyone has something more reliable than using one of these two methods ?
menno
(Menno Deij - van Rijswijk)
April 14, 2015, 10:39am
#2
It seems that the ExeVersion
that can be used in RhinoCommon and in C++ is lacking from Rhino_DotNet. I think that analysing the registry key is the most reliable after that.
MRhinoApp app = RMA.Rhino.RhUtil.RhinoApp();
string reg = String.Empty;
if (app.GetRhinoRegistryKey(ref reg))
app.Print(reg + Environment.NewLine);
string version = reg.Substring(reg.LastIndexOf('\\') + 1);
app.Print(version + Environment.NewLine);
In that string you should get 4.0, 5.0 or 5.0x64
