Hi everyone,
I am currently developing a Rhino / Grasshopper workflow (later integrated into a C# Rhino plugin) where I offset a mesh by moving vertices individually along their vertex normals.
The important part is: each vertex has an individual offset value → the values come from vertex colors,therefore I cannot simply use a standard global mesh offset or ShrinkWrap-only workflow
In generall it works really well, however for certain geometries (especially taller meshes with concave regions), I get local self intersections (e.g. picture. The white mesh is the original one; the red one is the offset mesh)
These problematic areas later cause unstable mesh booleans. The issue is NOT global. It only happens locally in small problematic regions.
I am specifically looking for a robust way to detect these local self intersections BEFORE offsetting the mesh.
Things I already tested:
Mesh repair approaches
MeshRay / MeshLine collision tests
Comparing old/new edge lengths
Testing offset rays against original mesh
I am now wondering:
Is there a known robust strategy for detecting local self intersections?
Has anyone implemented something similar in Grasshopper / RhinoCommon?
The solution ideally needs to work either in Grasshopper or RhinoCommon.
Any ideas, plugins, RhinoCommon methods, or computational geometry approaches would be hugely appreciated.
Thanks!
