Detect where subd is open
Hello people …
I have a Sub D structure … which is quite complex and big … When i wanted to Refference it into Grasshopper it would not do the Job nicely because the SubD was open…
Now i am Unable to Spot where i have done my mistake… Cant seem to find where its open .
Is there an easy way ?
Thannks
Hi, could you make a copy of the Subd, then convert it to nurbs, then use analysis tools for naked edges? Might show where to look.—-Mark
In the SubD Tools there is a “fill subd hole” command. Use this and select your whole subd and it should highlight the hole.
Thanks that was the one ! … I used “mark naked edge”
The problem was that i had one micro subd part floating outside the model . So Rhino thought its still open …
IT was only visible when in nurbs mode tho ! in subd mode it was invisible …
Anyways thanks alot for the help :smiley:
Tested with low face’s count
NackedSubDEdge
Ill remember that one too :wink:
Thanks
Hello - ShowEdges > Naked edges works on SubD as well as surfaces and meshes.
