Detect solid and hollow objects in a single Brep
I have a single Brep object which consists of multiple open and closed geometries, I want to check which geometry is closed and which is open.
Is there any way to do the same using Rhino API in C#
First use GetConnectedComponents() to get all sub-breps. Then test each for closedness with the IsSolid property.
https://developer.rhino3d.com/api/rhinocommon/rhino.geometry.brep/getconnectedcomponents
https://developer.rhino3d.com/api/rhinocommon/rhino.geometry.brep/issolid
