Detect if curve has been edited
If there is no way to attach user-text to geometry as a means of detecting geometry changes, how can I best find out of a curve has been edited in between script itterations?
Thanks
-Willem
Continuing the discussion from UserText on geometry not discarded when cp editing:
Hi Willem,
You can detect whether or not a Rhino object has changed by tracking its runtime serial number. RhinoScript does not expose any methods to obtain this. But using Python/RhinoCommon, you can do something like this:
def ObjectSerialNumber(object_id):
    rhobj = rhutil.coercerhinoobject(object_id, True, True)
    return rhobj.RuntimeSerialNumber
Anytime an object changes in any way, this number will change.
Does this help?
Hi Dale,
Thanks for pointing to this. It works for my needs:
For future readers: there was one typo in Dale’s snippet (rhutil i.s.o. rs) corrected below:
    rhobj = rs.coercerhinoobject(object_id, True, True)
Thanks
-Willem
