Hi there
I am having an issue with details and layouts as a plugin.
I have a code attached which when I run through EditPythonScript does what is required and makes a layout with a detail and sets the detail scale at 1:25
when i call on this script as a rhino command it runs, but the new detail does not scale to 1:25
This is a small part of a much larger code which i run as a plugin and the rest works fine. Ive played around for a while but am not sure what the problem is.
To be clear, my issue is that while this code works as a script, it does not set the detail scale right as a command.
layout_detail.py (803 Bytes)
Any help is appreciated
Thanks
