I’ve tried locking/unlocking the view. I’ve checked to make sure it’s not on a locked layer. I opened up a new file and copy/pasted that same view into the new file’s layout sheet and same result, no grips.
Can you tell us more about this detail and how it got in this condition?
We really need to log an issue to keep this from happening.
You are running the VA plugin? Was it any of the plugin commands that damaged the detail?
Is there a series of commands (VA or Rhino) that led to this very small control point display that you can repeat?
We see that that Detail is not displaying the control points correctly.
However they are still there. You can window select them and modify the detail.
The developer can likely fix it, if we can come up with steps that damage the detail in this way.
Please keep your eyes open for that may be causing this and report back.
Thank you for quick response. I am not sure when the issue happened. The detail views were created a while back, and I’m looking through my archived versions…it appears the issue appeared a while ago and I just now noticed because the same issue is present in my much older archived versions of this file.
So I can’t say what steps occurred that created the issue. However thank you for pointing out that I can still window select them. Not ideal, but it let’s me work around it.
