Detail Locking and Model Space
Looking for a way to lock a detail to objects in model space so that the detail always shows the same model view of the objects even if moved in model space. For example, if a detail is made in layouts and cropped to a clipping drawing, if the clipping drawing is moved in model space it may be helpful to have the detail view be associated with this update (rather than moving the clipping drawing and manually updating the detail crop).
Hi @Matthew_Schneider,
Thanks for asking.
We logged wish: RH-97269/Associate-a-Detail-with-Named-View-and-or-Geometry
However, it is not the way Rhino is architected.
These types of wishes get on the tracker, and can be considered in a future Rhino.
Currently layout detail is associated with a view, cplane and coordinates that correspond to the model and the layout.
Is is not associated with model geometry or even a named view.
If the model geometry changes location (such as a clipping drawing block), it will not update the detail, even if the details is “unlocked.” Currently, you need to work within these parameters.
Just curious, is there other software that you have used that works by associating geometry to the paper detail view?
Hope this helps.
Sincerely,
Mary Ann Fugier
Mary,
Thank you for the reply, very helpful in clarifying what is possible and why. To your question, no, I have not personally used other software that works by associating geometry to the paper detail view in the way I’m describing. The possibility to do so I thought could be more forgiving in scenarios where drawings are moved often, accidentally or intentionally (reorganizing model space), while maintaining a stable layout print set.
Matthew
Hi Matthew -
Something that you can do with the tools available today is creating a named view for a detail that look at things that you want to move. Then, in model space, first turn on the camera widget for the named view and move that together with the geometry. When done, update the detail to the named view. This won’t help against accidentally moving stuff…
