Detail-From-Curve skips a question when Preselecting a Curve
Detail-From-Curve skips a question when Preselecting a Curve in Rhino 9 BETA (15-09-2026).
When no curve is preselected you are asked to select a curve with the option of choosing the content of the detail (Defaults to Projection:Top). When a curve is preselected you always get the Top-view…
It would be relevant to be able to choose a Named View from your list of Named Views in a more modern way than the current implementation with “Browse”. It would also be nice to be able to preselect your prefered DisplayMode directly from the list of available (custom) DisplayModes.
A typical workflow will be adding a bunch of details all in Monochrome- or Concept- or Rendered- DisplayMode when you allready have a lot of other Details in your Layouts, so double-clicking or choosing NextDetail and changing NamedView and DisplayMode for all of them is timeconsuming.
CutterBench_1200_A4_Dimensioned.pdf (843.8 KB)
CutterBench_1200_A4_Exploded.pdf (862.2 KB)
CutterBench_A4_v9_Vector.pdf (105.7 KB)
CutterBench_A4_v9_Raster.pdf (723.7 KB)
Thanks @Erazmataz for your requests
RH-99660 (bug) DetailFromCurve: preselected curve skips projection prompt
RH-99661 DetailFromCurve: fewer clicks to pick a Named View
RH-99662 DetailFromCurve: sticky option to set the display mode of the new detail
So nice to get this nailed down before launch…
Looking forward to see you Wednesday in BCN.
Kind regards
Tim Elkær
@scottd This sample-file relate to the “CallOuts” and the IsolateInViewport we talked about today in BCN. Feel free to use the 3DM as an example. The designer of the bench is Niels Hvass. It is in production by Fritz Hansen and available for download in DWG from their webside. Regards Tim
