DesignSense, a modern, open-source tool for exploring design spaces
Happy to release DesignSense as open source!
DesignSense is a tool for filtering, understanding, comparing, and choosing among large collections of options, architectural designs, products, cars, houses, or anything else that combines visuals and data. In simple terms, it’s an advanced shopping interface.
More broadly, it helps you understand the statistical relationships within a dataset, explore trade-offs between parameters and performance metrics, and make informed decisions using both data and visuals. It’s designed for people with different levels of data literacy and different analytical needs.
It has two modes: Lite keeps things simple, serving as a robust, modern alternative to Design Explorer by CORE studio. Expert adds more sophisticated data selection and parametric analysis.
It’s free and runs in your browser. Your data is read there and never uploaded.
Try it
Where it fits in Grasshopper
Grasshopper makes and measures the options; DesignSense is where you make sense of them and decide.
  • Colibri (TT Toolbox, Food4Rhino; Rhino 7 and 8): Connect your sliders to Colibri Inputs and your results to Colibri Outputs — areas, costs, Ladybug or Karamba3D results, or anything else you can wire in. The Aggregator writes a folder containing data.csv and one image per iteration. Open that folder directly in DesignSense.
  • Optimizers (Galapagos, Octopus): Record every option the solver explores, not just the final ones. Colibri’s Aggregator can capture these as the solver moves the sliders. Because optimizers sample the design space unevenly, the charts reveal where the search concentrated. The guide explains how to interpret these patterns and combine a coarse sweep with an optimizer run.
  • 3D models: Include one .glb, .gltf, or .obj file per option, referenced in a model3d column and named to match the option’s image. In Rhino 8, use File → Export Selected → glTF. In Rhino 7, use McNeel’s glTF exporter or export OBJ with “Map Rhino Z to OBJ Y” enabled.
  • Goals: Name a column min:cost or max:daylight, or define goals after loading your data. DesignSense then reveals the best trade-offs between any two goals.
  • Back to Grasshopper: Export the filtered results or your shortlist as a CSV, including your ratings, notes, and custom criteria. Use it to start a smaller study or feed the selected input values back into Grasshopper to rebuild the options you’ve kept.
Design Explorer compatibility
  • Load data from a shared Google Drive folder, a GitHub link, or a locally served folder.’
  • The in:, out:, and img columns work the same way, so existing Colibri or Design Explorer folders can be loaded as-is.
  • The threeD column and its .json scenes are supported, and a Description column can be used to name the options.
See the guide’s section for Design Explorer users.
I’d love to hear what you think. Here, on GitHub, or through the app’s Help menu. I’m especially interested in how DesignSense handles your own studies, particularly large datasets, and what might be missing from your Colibri or optimizer workflows.
DesignSense is the result of years of research, thoughtful design, and user studies with architects and computational designers. It was developed in collaboration with Halil Erhan at SFU’s Computational Design Lab, with funding from NSERC Canada.
