Hello, I hope you’re doing well.
I’d like to design this seashell as a box that can open and close using Grasshopper. Could someone help me with this?
dimensions : 18 x 17 x 7 cm
7. This is not a do-my-work-for-me group
Many of us like to help, but it’s good to see effort on our part being matched by effort on your part. Questions in the form of “I need to do X but cannot be bothered to try and learn the software” will (and should) go unanswered.
coquillage.gh (15.1 KB)
Voici une traduction naturelle en anglais :
I tried to start design it, but it’s been difficult.![]()
Dear Khawla imp.
This looks already very nice. Well done. Some improvement possible (share elipses what you start with instead of re-creating), but nothing what changes the result.
What is the next step you are struggling with?
PS: For the top part, you could use the same technique (now creating ribs as first step, move them up/ down; interpolate + loft).
j’ai essayé de le faire ; mais j’ai obtenu un resultat qui ne ressemble pas à la photo et que le modèle souhaité
coquillage.gh (21.3 KB)
well you have to tell how you want to proceed (it is your design).
To give it “body” and make it from an open brep to a closed brep. You have to give this part you made “thickness”. Suggestion attached.
I would treat this as an inspiration sooner than something to replicate. Just thinking about how it would close, you can see it cannot work. Start with the closed form – that will ensure it clasps shut. Then assume it can hinge open.
Yes, it isn’t easy - especially when you’re trying to run before you can walk. Here is something to get you started - the example you shared doesn’t close completely, but hopefully you can see how to copy that if you want it to be identical. Also, you really need to read up on lists - taking clusters of individual items manually defeats the point of using grasshopper at all - have a look at modelab’s primer, unfortunately it’s in English https://modelab.gitbooks.io/grasshopper-primer/content/1-foundations/1-foundations.html
Shell.gh (28.9 KB)
I would struggle with this.
Thank you for your help. This is very close to what I’m looking for. I’ll try to modify the upper lid a bit because this is a cake box for celebration cakes, so it needs to be slightly taller to avoid squashing the cakes. I’ll also work on improving the box’s closing mechanism.
Have a play with this slider - should give you some good ideas
@Volker_Rakow I don’t think you would, if you have any questions, happy to explain but your post history has you playing with things more complex than this
