I’d like to design and build a couch table in the shape of an irregular polyhedron.
Top surface should have the shape of a polygon with 6-8 edges, bottom face with a different polygon shape. I’d like a tool to sketch the top and bottom faces, then define the hight of the table and position the polygons above each other (with free movement and rotation).
That definition then should create a block in form of a polyhedron.
I then need the specs for cutting out the shapes of all polygons (wood or MDF), ideally with a mitred cut.
Interested freelancers please contact me via ewald@btinternet.com
