Design Lamp from Vase
Nice. You only need to fix the seam of the yellow vase.
There is no seam on the Yellow vase which is made of Yellow Glass
The video is only the prototype of what I intend to do with the vase.
spooky, psychedelic coffee shop background music/noise, quite fitting to the lamp maybe. the lamp looks a bit retro 70s with a touch of retro 80s pattern from the 90s, i am not sure how to express it differently :speak_no_evil:
@cumberland surly is talking about this seen here. on your vase. it seems to be a mapping material issue, since you are not rendering it properly it does not seem to matter.
but if you are going to use this exact canvas on the shade maybe you could make that seamless either? it creates a harsh line.
This is only a prototype made of pictures in Rhino 7
There is no rendering it is in wireframe mode
There isn’t even a solid.
I used solids to make the form and then removed the solid
