Hello, would anybody show me how to design this shank?
Any suggestions would be greatly appreciated, I’m thinking a twist?
model is straight then twist it, then flow along a circle after it’s twisted.
also: make sure and use history for the flow so you can adjust it as needed.
Thank you much! I’ll give it a try.
Hi @joeyalbano2000
Since the grooves don’t go all the way through, I’d do something like this - main commands are InterpcrvOnSrf
, Fin
and OffsetSrf
Watch out when using InterpcrvOnSrf
- it sometimes needs a little bit of tender care to make sure the curve goes the right way over (or under) a closed surface.
HTH, Jakob
