Design failing
the design which passes through design check in etabs is failing in Karamba 3D. In Karamba 3D utilisation ratio comes out to be more than 1 whereas in etabs the same design with same material property , utilisation ratio is 0.7(max). Any suggestions where I can check the error ?
The Utilisation component in Karamba3D is written for EC3, more information can be found here: 3.7.7: Utilization of Elements :large_blue_diamond: | English 英文 | Karamba3D 2.2.0
