Design compound miters for picture frame corners
I want to use Rhino 8 to determine the miter angle and the blade tilt angle
needed to produce compound miter joints for picture frames that are inclined
at 20 degrees from the wall surface. A first test of my design method uses
flat boards that are 3/4" thick x 2 1/2" wide x 22" long. Attached is a 3dm
file showing two adjacent frame pieces intersecting in a right angle, and a
plane I would like to use as a cutting plane to make a compound miter joint.
I have been unable to get the plane to work as a cutting plane, and I have
also been unable to get the split and trim commands to work. Please try to get
the plane to function as a cutting plane so that you get the compound miter
joint I want. If you are successful, please send me a link to instructions
that describe what I should have done.
Hi @Terry_Crump
No file attached to your post.
RM
Sir:
The attached file shows one proposed compound miter joint, but if one clicks on either board, it is apparent that no cutting surface is present.
Compound miter design_3-18-2026.3dm (46.0 KB)
Hi Terry,
In the top view, draw a line where you want the join, select the line and use the _WireCut command. Select both the planks and follow the instructions to cut all the way through. Select the waste pieces and delete.
Compound miter design_3-18-2026 001.3dm (80.7 KB)
HTH
Jeremy
ps. Your cutting plane is a curve, not a plane, which is why you didn’t get a reaction. But that is moot as using a plane will leave you openings in the planks where they are cut. _WireCut leaves solid pieces.
Hello Jeremy,
Thank you for the suggestion and the description of mymistake. The Wirecut worked fine.
Thanks again,
Terry
