is there a way to deselect all non-planar surfaces in Rhino 5?
Thanks!
Hi Konrad - not without a script I think. I’ll see if I can make you something in a bit here.
DeselectPlanarSurfaces.py (291 Bytes)
Put the script file here:
/Users/NAME/Library/Application\ Support/McNeel/Rhinoceros/Scripts
annd then make a macro for
_-RunPythonScript DeselectPlanarSurfaces
Heh, sorry - that was planar, I’ll make one for non…
DeselectNonPlanarSurfaces.py (295 Bytes)
Rhino 5
not sure if there is
_SelPlanarSrf
already.
so you can selPlanarSrf → look them → select the rest.
you can also work with colors, layers, names instead of looking / unlooking
Hi Pascal,
works perfectly! thank you so much! This is a great help in the early stages of my modelling process to check for planarity, which is often lost when pushing control points around.
unfortunately _selPlanarSrf is not available in R5
