I work with a combination of 3d geometry and point clouds. When ever we render the diagram, the point clouds become desaturated and the color doesn’t look as vibrant as in shaded. I tried looking at the lighting but that doesn’t seem to be the issue. Our diagrams are highly criticized so if there is a fix to this, it would greatly help.
Hey @Rhino_Noob,
If you create a copy of the rendered
display mode, and edit the viewport settings -> linear workflow settings
to custom
, and then tweak the output image gamma
to increase the contrast, you should be able to get a similar level of contrast as the shaded
mode. I’ve attached some screenshots so you can see the difference and relevant settings.
Hope this was what you were after!
Luke
Thanks. I think this may help.
