Depth of wrapping wall layers
Is there any way to control the “depth” of the wrapping wall layer at openings? If I put a window in the standard “Block on Mtl. Stud” wall style, the plasterboard will wrap all the way towards the exterior surface of the wall:
Whereas in the documentation, it seems like it’s possible to stop the wrapping at the inner side of the openings, which is more logical since we don’t want to expose plasterboard to rain:
If you select the Masonry layer in the “Block on Mtl. Stud” style and set ist Construction Type to Normal, instead of Core, you will get the desired result.
Thanks Alfonso!
