The solution to all this might just be using different display modes (or basing my custom display modes off different display modes). Using custom linetypes. Or not using custom linetypes… or who knows. It takes a lot of trial and error.
But anyways… here’s my issues. #1 is far clipping. I’m using planes to represent grids and levels. If I can get this to work it’s going to be pretty awesome.
I’ve got things looking perfect in my layout before I print:
The red lines are actually vertical planes. They’re cut with my clipping planes representing level 2.
When I print I lose the desired look. Everything looks like it’s supposed to except for the grid lines. That line is just left over junk and I have some no plot layers showing:
If I print in Shaded mode the issue goes away. I’d obviously have to fix my line weight of course but the line otherwise looks as it should:
I haven’t figured this out yet but I might be able to take advantage of it. It’s just the plane representing the level (plus a little test plane):
The settings for that layer seem to be the same as my grid line (grid plane) layer’s. It might just not be updating and may require that I re-create the detail. Not a problem once the template is sorted but makes it a little more challenging to experiment.
There’s various other clipping issues Update - not using the clipping depth seems to alleviate this now. I had tried before but it didn’t work. I’m not sure why but it’s either a setting I had flipped or an updating issue - instead of the depth I’m just using two clipping planes now and it seems to work in vector mode just as intended
Taking the scaling out of the Section Style’s boundary line scaling fixes it but new problems appeared when I applied a custom line style to the layer. I can dodge that too though… trial and error.
One last issue, not a biggie:
These pavers aren’t adopting the viewport overrides.
But they print properly:
The reason for posting this now is because I just want to get advice on what to avoid. I’m basing my display modes (for printing) off the Technical display mode. I might avoid custom line types (or applying them in certain ways). It takes A LOT of experimenting even when everything works correctly.
It’s hard to be concise and really narrow down the problems. Each option has multiple possibilities (print display being on/off, display mode settings). There are infinite combinations. So finding the right combination is key.
The “Far” or “Depth” clipping seems a little bit broken. I’m having issues both with using clipping plane depth, and with using two clipping planes to achieve the same result. The later seems more reliable. I was hoping that I could use the second clipping plane’s custom section style properties to sort out the issues but it feels like it gets overridden or something (and likely depends on the display mode… maybe…). If I can get around this I can probably sort out everything else quite easily.
PrintDisplay is a tripping hazard. It’s a good tool but when it doesn’t work it’s a gut punch.
When I have more energy I’ll have another round at this.
