Dents being created by both sweep 2 and networksrf
I’m trying to make a smooth surface but both networksrf and sweep2 are creating dents. I’ve checked to make sure all the curves are aligned as far as I can tell. Matchsrf is able to fix the middle seam to look smooth enough. But I can’t manage to fix the dents on the sides. Adding more sweep shapes seems to make it worse.
surface dents.3dm (602.6 KB)
If there are no particular needs you can try Patch which however generates a cut surface.
Then, to create the hole, you can use Split or Trim.
Thank you! It looks fine for my purposes, but is there a way to do it besides patch?
Even with NetworkSrf you get a good result but, in this case, it seems better to me with Patch.
