Hello everyone,
I’ve been trying to find a way to remove and add new geometry to nested blocks using Python. Using a recursive function I am able to change the properties of the nested geometry, but trying to remove or replace geometry does nothing. The DeleteObjects functions returns a success, but nothing happens to the block geometry. Example code below, highlighted line does nothing.
def RemoveBlockGeo():
ids = rs.GetObjects("Select block instances", 4096, preselect=True)
if not ids:return
targ = rs.GetLayer()
if not targ:return
names = list(set([rs.BlockInstanceName(id) for id in ids]))
done = []
def BlockDrill(names):
while True:
if len (names) > 0 :
name = names.pop()
else: break
done.append(name)
temp = rs.BlockObjects(name)
for tempid in temp:
if rs.ObjectType == 4096:
**rs.DeleteObject(tempid)**
rs.Redraw()
for tempId in temp:
if rs.IsBlockInstance(tempId):
tempName = rs.BlockInstanceName(tempId)
if tempName not in names and tempName not in done:
names.append(tempName)
BlockDrill(names)
BlockDrill(names)
if __name__ == "__main__": RemoveBlockGeo()
