Deleting diagonal line from surface
I try to get a surface between these grid points. The diagonal lines have to be removed. Does anyone know how to remove these? if that does not work i want to do it without mesh.
Afstudeeronderzoek_Script_Prototype3.2_Wiskundig.gh (43.6 KB)
missing
Looks like a mesh instead of a NURBS surface. Way, WAY too complex :bangbang:
Afstudeeronderzoek_2024Apr24a.gh (20.6 KB)
P.S. I don’t know why your code is so complex? It appears you are exporting data to XML at the end? But the initial geometry can be this simple:
Afstudeeronderzoek_2024Apr24b.gh (11.0 KB)
Thanks for helping me out. I’m a beginner with Grasshopper that’s why i can’t find all the components and try to do it in other ways. The complexity is done because i have to be able to change the coordinates by a mathematical formula, so that the coordinates change parametric with the formula.
And you’re right i’m making an XML-file at the end.
ps. with the ‘surface split’ component i get the points where the surfaces intersect. Is there an easy way to separate the center points from the edge points in separate lists?
Afstudeeronderzoek_Script_Prototype3.2_Wiskundig.gh (42.3 KB)
Probably yes but I don’t know know what you are trying to do.
sorry for the confusion.
I’m creating a point supported floor that can be transported with an XML file to SCIA Engineer (construction calculation software).
The points have to be supported by supports, so i try to get the coordinates from the intersection points of the horizontal lines and vertical lines. To these coordinates i will connect the supports.
But the intersection points on the 4 edges of the surface need to have different supports than the coordinates in the middle part. That’s why i need the intersection points on the edges (blue) as a separate list and the intersection points in the middle (green) as as separate list.
Screenshot_2
Afstudeeronderzoek_2024Apr24c.gh (19.4 KB)
Use the Value List (blue group) to choose which list of points is labeled.
P.S. You can rearrange components to put Sort Points before Dispatch, like this:
Afstudeeronderzoek_2024Apr24d.gh (19.6 KB)
