Deleted groups always listed
Hi @piac,
it looks like in V6, deleted groups are listed even when ignoreDeletedGroups = True.
I see this in the python script editor using:
scriptcontext.doc.Groups.GroupNames(True)
and in GH when i use:
Rhino.RhinoDoc.ActiveDoc.Groups.GroupNames(True)
Funny thing is if i iterate over the group names, get the index and query if they are deleted, they are not and their index is not -1.
Is this a bug or am i doing things wrong ?
_
c.
I am looking into this!
Hi @clement
so, it appears to be that the dialog does not show any group without members, because they cannot be selected. However, simply deleting members of a group will not delete the group.
To do what the dialog does, you can try this:
import scriptcontext as sc
def RhinoSelGroupsList():
    dialoglist = []
    for g in sc.doc.Groups:
        if g.Index < 0: continue
        members = sc.doc.Groups.GroupMembers(g.Index)
        if not members: continue
        dialoglist.append(g.Name)
    return dialoglist
print RhinoSelGroupsList()
In the meantime, I’ll ask if this is expected behavior.
I think this should be improved. I logged RH-44558.
Giulio
Giulio Piacentino
for Robert McNeel & Associates
giulio@mcneel.com
Hi @piac,
i’ve noticed that too. Currently checking if there are group members seems to be the only way to get the non deleted groups. Is it expected that:
lists group names of deleted groups ? I thought the True stands for ignoreDeletedGroups ? What really concerns me is that, if i use:
index = Rhino.RhinoDoc.ActiveDoc.Groups.Find(group_name, True)
in GH (RH6), it gives me an index value which is not -1, on deleted group names. So your above example to check for g.Index < 0 would not apply in the future ? (I used that very often).
_
c.
@clement, while @dale adds more comments indicating how groups deletion works, do you have a sample that works differently in V5 and in V6?
That way maybe we can help at least there!
Thank you @piac, I’ve replied there.
Probably i’ve asumed similar like you that if a group is ungrouped or if objects in a group are deleted, the group is deleted as well.
_
c.
