Delete UserObject does not work on MacOS
I noticed a small bug using custom UserObjects. When I try and delete them from within Grasshopper, nothing seems to happen. The only way to remove them is to go to the actual UserObjects folder and manually delete them.
I can make a new UserObject just fine, and add it to a new toolbar just fine
but then if I right-click and select ‘delete’, (note, the text note in the popup is clipped as well?)
which does not do anything to the file in the UserObjects folder.
If I go in and manually delete it, it does all work that way though, and the toolbar updates as expected.
Environment:
  • Macbook 2021, Apple M1 Max
  • OS 12.2 (Monterey)
  • Rhino Version 7 (7.15.22039.13002, 2022-02-08)
all the best,
@ed.p.may
Thanks for reporting, I’ll try and replicate this and file a bug report. I think just the message needs to be fixed.
Hello @Japhy, all
I just wanted to note that this bug still hasn’t been resolved yet and I am still getting the same behavior (not deleting).
Environment:
  • OS 12.5.1(Monterey)
  • Rhino Version 7 (7.26.23009.07002, 2023-01-09)
best,
@ed.p.may
Embarrassingly I have no recollection of this (almost a year ago). I dig into this and get back to you my findings. Thanks
thanks @Japhy - no worries. If there is an easy fix it would be great though!
best, @ed.p.may
this is on the list as RH-72927 Mac Grasshopper UserObject fails to delete from drive
