I do want to adapt a script that I do found on this forum to my needs and I can’t find a way to delete the used points. If I do preselect all the geometries from the 3DM files attaches bellow, the script it is creating 3mm diameter circles to eve point that it is preselected. Unfortunately I can’t find a way to delete only the used points after they was used to generate the circles.
I am trying to use the rs.DeleteObjects(ptIDs)
but unfortunately this method also delete some of the generated circles and also do throw an error.
How I can delete only the used points without deleting anything else?
I am using Rhino7SR37 on Windows.
# https://discourse.mcneel.com/t/scriptcircle-creation-script/166863
import scriptcontext as sc
rs.AddLayer("Drill_3")
rs.CurrentLayer("Drill_3")
def CirclesToPoints():
tol=rs.UnitAbsoluteTolerance()
# if "CIRCTP_Dia" in sc.sticky: user_dia = sc.sticky["CIRCTP_Dia"]
# else: user_dia = 3.0
user_dia = 3.0
msg="Select points to apply circles - orientation plane will be active view"
ptIDs=rs.GetObjects(msg,1,preselect=True)
if not ptIDs: return
plane=rs.ViewCPlane() # use the current CPlane
# dia=rs.GetReal("Circle DIAMETER",user_dia,tol)
dia=user_dia
if not dia: return
rs.EnableRedraw(False)
pts=rs.coerce3dpointlist(ptIDs)
copies=[]
for pt in pts:
plane.Origin=pt
copies.append(rs.AddCircle(plane,dia/2))
# rs.SelectObjects(copies)
rs.UnselectAllObjects() # Deselect all objects
rs.SelectObjects(ptIDs) # Select the used Points
# sc.doc.Objects.Delete(ptIDs,True) Delete used points
rs.DeleteObjects(ptIDs) # NOT WORKING PROPERLY
# sc.sticky["CIRCTP_Dia"] = dia
CirclesToPoints()
rs.CurrentLayer("Default")
Delete points.3dm (165.3 KB)
