Delete of objects causes crash (Wall and Slab) post 3.8.1 update
I have recently updated to VisualARQ 3.8.1 and a file I have been working on either side of the update now crashes when I delete specific VA Slab, Wall or Roof components. It also crashes when I try to update the boundary of the slab.
I have tried to replicate on other files but I haven’t been able to do so.
Is this a known issue / has anyone else found this? Just wondering what to do to save the file and still be able to continue working on it as there is around 50 hours of work in the file so far!
Thanks in advance for any help.
Hi William, can you share that 3dm file? this way we can investigate what’s happening.
Thanks Francesc, I have emailed the file over.
Hi William, got your file, thanks! I could reproduce the crash, so we will fix this immediately. This issue doesn’t happen in VA 3.8.0 so I’ll send you an installer of it so you can continue your work until we fix this.
That’s great, thanks Francesc :+1:
