Delete object name
To set a name to a object I use the command _SetObjectName. But I want to delete the objects name (empty in “name” in object properties) Is that possible?
/F
SetObjectName to “” (two quotes no space between)… --Mitch
Thanks!!!
You can also just put your cursor in the Name field in the Object Properties tab and set or delete the name there.
Thanks Mark :wink:
