How do we remove a texture map (an image) from a texture set material ?
I only find the way to replace a map but not to delete it
Does the “render preview” option translates in a faster and less quality render ?
The preview looks, both in quality and time to render, like a normal render…
Hi Joao,
Click advanced after double clicking the texture set material to edit it. Then choose the textures section. You can right click any texture here and delete it.
That preview option is useful with the default Rhino Renderer. Render Preview won’t however effect Flamingo nXt since the rendering is calculated over time and not by a sample number.
