Hitting Delete with where cursor is doesn’t delete numbers.
Rhino 6 SR17 2019-8-24 (Public Build, 6.17.19236.01022, Git hash:master @ 06b69c5cc21d880aa793a5a7cfd454a66f6213bb)
License type: Evaluation, build 2019-08-24
License details: Cloud Zoo. In use by: Karl Mochel ()
Expires on: 4315010-04-30
Apple Intel 64-bit macOS Version 10.14.5 (Build 18F132) (Physical RAM: 16Gb)
Mac Model Identifier: MacBookPro13,3
Machine name: OSXKMOCHMBP15
Language: en-US (MacOS default)
AMD Radeon Pro 455 OpenGL Engine (OpenGL ver:4.1 ATI-2.9.26)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
Graphics: AMD Radeon Pro 455
Displays: Color LCD (258dpi 2x), ASUS PB278 (109dpi 1x)
Graphics processors
Intel HD Graphics 530 (1536 MB)
AMD Radeon Pro 455 (2 GB)
Color LCD (1680 x 1050)
ASUS PB278 (2560 x 1440 @ 60 Hz)
USB devices
Apple Inc.: iBridge
Bluetooth devices
None
Third party kernel extensions
com.techsmith.TACC (1.0.3) 851BEDD1-1D12-3756-A948-978610078DEF
com.crowdstrike.sensor (95.05) 5B485DC0-510D-3289-B7BA-6CD9D6078F54
Third party plugins
Rhino plugins
/Applications/Rhinoceros.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 6.17.19236.1022
/Applications/Rhinoceros.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 6.17.19236.1022
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 6.17.19236.1022
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 6.17.19236.1022
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 6.17.19236.1022
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 6.17.19236.1022
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 6.17.19236.1022
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 6.17.19236.1022
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 6.17.19236.1022
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 6.17.19236.1022
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 6.17.19236.1022
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 6.17.19236.1022
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 6.17.19236.1022
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 6.17.19236.1022
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 6.17.19236.1022
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 6.17.19236.1022
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 6.17.19236.1022
/Applications/Rhinoceros.app/Contents/PlugIns/export_SKP.rhp “SketchUp Export” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/Export_UDO.rhp “Moray Export” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/import_RAW.rhp “RAW Triangle Import” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/Import_DGN.rhp “MicroStation file import: import_DGN” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/import_VRML.rhp “VRML Import” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/Import_WAMIT.rhp “WAMIT import” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/import_SKP.rhp “SketchUp Import” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/Export_RAW.rhp “Raw Triangles Export” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/MPlane.rhp “MPlane” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/Export_XGL.rhp “XGL Export” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/RhinoRender.rhp “Rhino Render” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/Export_CD.rhp “Cult3D Export” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/export_LWO.rhp “Lightwave Export” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/export_SLC.rhp “SLC Export” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/import_3MF.rhp “import_3MF” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/export_STEP.rhp “STEP Export” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/export_3MF.rhp “export_3MF” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/Export_WAMIT.rhp “WAMIT Export” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/Import_SLC.rhp “SLC Import” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/Import_OFF.rhp “OFF Import” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/Squish.rhp “Squish” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/Export_X_T.rhp “Parasolid Export” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/Import_M.rhp “Import_M” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/Import_X.rhp “X Import” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/import_IGES.rhp “IGES Import Plug-in” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/export_AI.rhp “Adobe Illustrator Export” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/Displacement.rhp “Displacement” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/import_LWO.rhp “Lightwave Import” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/export_SAT.rhp “ACIS Export” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/Export_CSV.rhp “Comma Separated Value Export” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/import_PDF.rhp “PDFReader” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/export_STL.rhp “STL Export” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/import_VDA.rhp “VDA Import” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/import_STEP.rhp “STEP Import” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/export_FBX.rhp “Export_FBX” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/Import_SolidWorks.rhp “Solidworks Import” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/import_STL.rhp “STL Import” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/Export_RIB.rhp “Renderman Export” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/import_FBX.rhp “Import_FBX” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/export_Points.rhp “Points Export” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/export_VDA.rhp “VDA Export” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/Export_X.rhp “X Export” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/CreaseAngle.rhp “CreaseAngle” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/export_3DS.rhp “3D Studio Export” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/import_PLY.rhp “PLY - Polygon File Format Import” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/MeshTools.rhp “MeshTools” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/import_Points.rhp “Points Import” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/MeshFromPoints.rhp “MeshFromPoints” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/export_VRML.rhp “VRML/X3D Export” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/Import_GTS.rhp “GTS Triangle Import” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/Export_GTS.rhp “GTS Export” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/PlugIns/Export_POV.rhp “POV-Ray Export” 6.17.19236.1002
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 6.17.19236.1022
/Applications/Rhinoceros.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 6.17.19236.1022
