Delete invalid components
What Python or C# code can be used to delete invalid components (like in the image)?
Remove Placeholders.ghpy (29 KB)
It is not C or Python (part of the FENNEC plugin) but does the job if you OK with this solution.
You should be able to right click and delete placeholder…
@Yatchun
Also Ctrl+A to select everything (including placeholders), then Ctrl-selection rectangle to un-select everything. This should leave only the placeholder objects selected. Which then can be deleted.
This method is not feasible.!
This method is feasible, but it is troublesome.
This method is feasible, but I just want to try deleting without using plugins and instead using code.
What version of Rhino are you using?
Rhino 7…. That explains why you don’t have the command
Hi Martin.
Interesting… I have a V7, V8 and V9. In none of these removing placeholders with right-clck is possible.
I have it Rhino 9 and Rhino 8
Ctrl + A to select everything (this will ignore the invalid component), and copy / paste in a new file.
This is the most stable approach for me for years.
