Delete hole (UntrimHoles) bug
In the file below, trying to UntrimHoles the center hole makes the whole part go away except for one surface. Probably because the bottom part of the hole crosses a surface seam. Checked both in V8 and the WIP. One for the “can improve” list.
DeleteHoleBug.3dm (3.3 MB)
I guess deletehole keeps deleting until it finds a surface with an internal trim. In this case that means only the top face remains.
I agree it would be nice if these kind of untrims across seams would work. I imagine though that it would rather become a removeface command where you need to select all the faces you want to eliminate from the model.
I don’t see why that could not be automated, since Untrim on the extracted bottom surfaces works.
Edit: this is the YT that has a similar case, yet more complex
RH-31973 Untrim - intelligent ‘remove feature’ feature
