Delete all tree branches - except the First one
Fairly simpel question.
Question: Delete All Tree Path - except - the first path-nr.
e.g.:
{1;2;7;7;7} → {1}
{2;3;8} → {2}
{8;0} → {8}
I have come up with the dollowing solution, however I have a feeling that there must be a more easy solution… (Path mapper component?)
any suggestions?
2023-05-18 Keep only - First - Tree Branch.gh (11.8 KB)
Thanks,
Tree Branch_2023May18a
Tree Branch_2023May18a.gh (12.9 KB)
Thanks for your quick reply.
However the desired result is:
any suggestions?
That’s very different from what you asked! Moving the goal posts… :frowning:
Tree Branch_2023May18b
Tree Branch_2023May18b.gh (13.7 KB)
I’m fairly disappointed to learn that {x;*} → {x} does not work, I thought it was the case…
You could do that :man_facepalming:
A better approach would be to avoid these trees with different levels.
2023-05-18 Keep only - First - Tree Branch.gh (18.8 KB)
Totally agree with your {x;*} statement…
But this is a nice workaround.
Many thanks
I never ever use Path Mapper for two reasons:
  1. It’s syntax is complicated.
  2. It’s fragile - when the upstream data structure changes, it breaks.
I also tend to avoid it for the same reasons.
The solution with Replace Paths in the original post is the most robust solution, though a bit longer.
