Delay working within cluster?
I would like to run a few rhino commands from within a cluster one after another,
to be able to run a command in rhino from gh, I need to make a delay in order the commands are triggered one after another instead of all at once.
Outside the clusters I have two solutions, one based on generation plugin counter, the other on anemone older version counter, I check counts, evaluate and if the right number on, I trigger the command, is there a way how to achieve running commands one after another in a cluster? as I am not able to just connect the commands, as rhcommand from lunchbox does not provide output
thank you
