The curvatures in the image above are all continuous. The height of the curvature comb is proportional to the curvature.
The rate of change of the curvature is discontinuous at the kinks in the curvature.
david summed it up pretty nice in one sentence nothing to add, only that you can combat discontinuity quite well with the command fair, sometimes hitting it a few times of course.
do you have any idea how i can switch to english? the page seems to autodetect my system language and i have no chance reading it in english.
@John_Brock Thank you for the link.
I need to go through it couple of times…
May come back to you for some questions later…
@davidcockey For the curves of deg3 drawn with
6control points, is it so that where the discontinuity of the curve is, so kink of the rate of change in curvature, is where two curves are connected at a tangent?
In that case, is the curve after that kink a deg2 curve as it is drawn using 3 control points?
@RichardZ In the screenshot attached,
does the curve on the right still have a difference in the rate of curvature or is it slightly off if you zoom in?
I’ve yet to try the fair command…
At a kink in the curvature graph the curvature is continuous, but the rate at which the curvature changes as you move along the curve is discontinuous at the kink.
A discontinuity in curvature results in a discontinuity in the curvature graph
A degree 3 curves has continuous curvature unless two or more control points are stacked on top of each other. Two control points on top of each other may result in a discontinuity in curvature. Three control points on top of each other may result in a kink in the curve.
A degree 3 curve with n control points and no control points stacked has n-3 “spans”. Each span in a degree 3 curve has continuous curvature and continuous rate of change of curvature. Curvature is continuous between spans, and rate of change of curvature may be discontinuous between spans.
A degree 2 curve has continuous tangency unless control points are stacked on top of each other. Two or more control points stacked may result in a discontinuity in tangency.
A degree 2 curve with n control points and no control points stacked has n-2 “spans”. Each span in a degree 2 curve has continuous tangency and continuous curvature. Tangency is continuous between spans, and curvature may be discontinuous between spans.
@davidcockey
Thank you for your detail explanation.
I’m starting to understand, but seems I need to study further.
So deg 2 crv promise tangency, deg 3 crv tangency& curvature continuous unless stacked.
Deg 4 crv will I suppose add continuous rate of curvature curve?
Seems I need to go study curve point, curve edit point, span, and knots and their relations.
And after that, pros and cons for different degrees and their practical uses.
Thank you again, I might need to come back to this post later.
For now I’ll use keywords to search and find some materials.
Years ago, there was a really good beginning tutorial from one of the marine designers, that started with an introduction to NURBS curves that described all of this very well.
Sadly, I have lost track of it.
Gerard wrote this one that has some great information: Rapid_Hull_Modeling_in_Rhinoceros.pdf (308.7 KB)
That’s the one; Rapid Hull Modeling.
for my rhino university basic courses i use the attached pdf to explain curve degree, single-span and multi-span curves, because it has simple explanations and good illustrations. i downloaded it some years ago from pivot.no.
hope, it helps.
rhino_basics.pdf (2.5 MB)
You can see the explain instructions in vimeo.com…
… Rhino3D tutorials chanel.
(Curves curvature and tang.)
Greetings
A good understanding of the relationship between a multipoint (piecewise) degree 3 B-spline to the more basic 4 point degree 3 spline can be had by ConvertToBeziers command. See how the new CPs relate to the originals control cage.
Hi Toshiaki,
you can find many good foundational explanations with nicely explanatory images here and here.
Although this is from Autodesk Alias Automotive, many concepts apply to Rhino as well, being a NURBS based surface modelling software. We use both Alias and Rhino, with a good dose of SolidWorks in the menu ; )
@Lagom
Thanks for the link! Great stuff.
Is SolidWorks was a little cheaper I’d like to give it a try…
