Deforming a Hexgrid to an Asymmetric Disk
Unfortunately, I’m stuck on this project. I’ve been trying for a while now to “morph” or deform this 2D geometry (hexagon-circle) onto a second circular ring surface (which is eccentric). Unfortunately, I wasn’t able to make much progress with the surface morph, since it always refers to a rectangular area.
I’d also be happy to hear other suggestions for how I can distort the pattern using eccentricity.
Maybe someone can help me out. Thanks
Deform2D.gh (22.6 KB)
Hello
there are many ways to do what you want. What seems a simple way is to make a loft with the 2 circles.
Or some more complex way
Deform2D_ld.gh (15.4 KB)
But the result could be surely better using Kangaroo
See the discussion
In this case, you need an untrimmed surface to map your curves to. Maybe this approach?
Deform2D_Rail Revolution v1.gh (13.3 KB)
This is how it is done with native components:
Deforming a Hexgrid to an Asymmetric Disk VR 1.gh (21.2 KB)
That’s not a problem since Hexagonal creates a Hexgrid in (close to) rectangular bounds and Sporph will map from any surface shape to another. @laurent_delrieu 's Hexagon On Surface is useful as it will map to periodic surfaces well, which is half the work in the script above.
You could also attempt to map to the surface of an overlapping disc.
